STUART'S WEB SITE
Date:  10-20-2013
Number of Hours:  4.00
Brief Description:  RH Elevator Leading Edge Rolled
Started to roll the control surface leading edges, no dificulties here. I followed the instructions on edge rolling, set out in the assembly notes, they worked ok. I do suggest, that you have on hand a few different diameter rolling tubes, I started with a 35mm dowel purchased from the hardware store, for the first bend. After this I used about a 15mm rod to do the outer most edge, the idea being that a slightly tighter bend near the outer edge, would give me a better lap joint, so in all it worked.
