Brief Description: Vertical Stabiliser Dimpled Match Drilled
TIME TO HAVE A CRACK AT THE VERTICAL STABILISER, AFTER A SHORT BREAK FROM THE TIN BIRD. TO MY AMAZEMENT,THE VERTICAL STAB WENT TOGETHER WITHOUT A HITCH. ALL PARTS WERE AGAIN ASSEMBLED AND CLECOED,FOLLOWED BY MATCH DRILLING. THE RIG WAS THEN DECLECOED DEBURRED,AND DIMPLED,ALSO PREPARED FOR PRIMING. THE DIFFERENT COLORED RIB IS FROM THE HORIZONTAL STAB,I HATE IT WHEN THEY STOP PRODUCING A CERTAIN PRIMER,AND THEY TELL YOU THIS IS THE DIRECT REPLACEMENT. YOU CAN HARDLEY TELL THE DIFFERENCE.
