Brief Description: Preparing inboard ribs on horiz stab
PREPAIRED HS-404 & HS-405 INBOARD RIBS AS PER PLANS. NOW THE ASSEMBLY,ALL HAD GONE WELL ALLTHOUGH I WAS NOT HAPPY WITH THE ALIGNMENT OF THE TWO RIVETS JOINING THE HS-404 & HS-405 RIBS THROUGH THE SPAR HS-702,IN RELATION TO THE UPPER AND LOWER RIVETS, SO I DECIDED TO REORDER THE SPARS AND RIBS ASSOCIATED,AND GIVE IT ANOTHER SHOT. IT ALL PAYED OFF AND I AM NOW PLEASED THAT I DID. IMAGE 2 SHOWS THE NEW ASSY,CLECOS ARE NOW IN LINE WITH UPPER AND LOWER RIVETS, ALSO THE HS-404 NOSE RIB WAS TRIMMED A LITTLE LESS THAN SHOWN IN IMAGE1,GIVING A MUCH CLOSER FIT BETWEEN THE REINFORCEMENT & SPLICE ANGLES.
