ONCE AGAIN GATHERED REQUIRED PARTS FOR THE FORWARD SPAR,IDENTIFIED AND MARKED ALL PARTS FOR ASSY.CUT AND SHAPED HS-710 AND HS-714,AS PER TRIM DETAIL.PREPARED SPAR HS-603PP,DEBURRED MATCH DRILLED,DIMPLED AS REQUIRED.SMALL ERROR AS SEEN IMAGE ONE,I COUNTER SUNK ONE OF THE FUSE ATTACH HOLES. THIS WILL NOT BE A PROBLEM AS LATER THIS HOLE WILL BE ENLARGED( WHEN FITTED) TO 3/16". PRIMED ALL PARTS, AND RIVETED THE REAR SPAR AS PER INSTRUCTIONS.
