Brocks RV-7A
Date:  1-23-2013
Number of Hours:  4.00
Brief Description:  Flap Reinforcement and Aileron Gap Fairing Riveted
Today, I started by using the new tap and die set I got for Christmas (thank you mom and dad) to create the threads for the wing tie downs. I then riveted the flap reinforcements to the rear spars. I then riveted all aileron rivets I couldn't get to with a squeezer. Next, I prepped the aileron gap fairings. I then cleco'd and match drilled all holes. Finally, the clecos were removed, holes were deburred, appropriate holes were dimpled, and the fairings were riveted to the rear spar.
