Brocks RV-7A
Date:  8-16-2012
Number of Hours:  5.00
Brief Description:  Left Fuel Tank Ready To Be Sealed
Today, I began by finishing the left fuel tank. I disassembled the tank and deburred all holes. I then removed the blue from the rivet lines and dimpled the wing skin using a DRDT-2 dimpler. I then dimpled the tank ribs using a pneumatic squeezer. I also fitted the fuel cap and drilled the attachment holes. I also fitted and drilled the bottom fuel drain attachment. I then fabricated the fuel tank vent line holder bracket. Finally, I drilled all holes for the right fuel tank.
Dimpled Left Fuel Tank Skin
Dimpled Left Tank Ribs and Stiffeners
Right Fuel Tank
Right Fuel Tank
