Today, I primed the ribs, reassembled the vertical stabilizer, and set all of the rivets that could be set with a hand squeezer (the rivet gun will have to wait until daytime). I then began working on the rudder assembly. I began with the left side skin and left stiffeners. I cut the stiffeners, and radiused all ends. I then match drilled all holes, disassembled, deburred, dimpled, and reassembled. The stiffeners were cleco'd into place and will also have to wait until daytime to be back riveted to the skin.
