Finished installing nutplates for lower cowl slot filler.
Weighed plane in prep for FAA Airworthiness inspection.
A little heavier than expected --1917 lbs with all fairings. Will look into ways to reduce this going forward. CG appears ok but some numbers aren't adding up right.
