Found Elevator trim extension wiring had come apart, so that explained the lost sigenal to the G3x. -Fixed.
Rudder trim-- Replaced servo to tab actuator rod with a a longer rod. This allowed for some left trim and reduced the maximum right trim. Calibrated and marked G3x display.
Right fuel level sensor was perplexing. Checked resistance in unit and it was ok. So, I pulled the float sensor.UGH!! When the senosr finally came out I found the problem- NO FLOAT! Apparently during storage, transport , and install--- it fell off. It took 45 mins. of trial and error in the sport of tank fishing to retrieve the wayward item.
Now, it is connected to the senso armr with a small bit of proseal.
Will reseal tank next time and start the curing clock again.
