Found green ground power bulb came out of bezel- needs super glue.
Continued trouble shooting Panel lights switch. Not sure why the diodes aren't doing their job, but will make switch "Bright" function only control flood lights. Rewiring Map lights to function correctly.
Added clamp to GSU73 static line connection.
Updated G3X to Version 10 and added calibration data for MP and Oil Press guages. RPM sensor caibration data still needed.
