Brief Description: Avionics ground and flap sensors
My main ground bus was getting full and difficult to insert tabs, so I added an avionics bus. 24 tab unit from B&C mounted near orginal unit. Moved all avionics related ground over to new locations.
Finished up 4 more ground connections to main ground bus.
Fabricated mount for microswitch inputs to AFS AOA and TCW trim speed controller.
Drilled left flap horn for flap postion unit. Routed flap postion wire from flap controller to postion sensor.
