Cut holes for seat heat control switches. They are about 98% the right size. Will finish after painting panel to get a really snug fit.
Enlarged/ cut holes for the AOA control buttons and the Fuel guardian cancel/test switch.
Drilled first hole for what I thought would be the pitot heat warning light- rethinking that idea. May put both door warning lights above ELT control and tie into the AN-21 controller.
Worked on AN-21 controller mount. Intial location had interference between connector and GSU73. Changed location to behind sub panel. That was a fun location to reach now that it is installed.
