Flandy Rv-10
Date:  6-10-2015
Number of Hours:  5.00
Brief Description:  Throttle mount/ wiring/ heater testing
Throttle Mount--
Primed, drilled, countersunk and riveted nutplates to mount modification. Installed mount. Cleaned up wiring and up-sized an adel clamp that will be underneath the throttle structure.
Tested heater control valves- rear position controller worked but not front. Tested both actuators on rear controller-OK. Checked voltage on input pins--OK. Called TCW- waiting.
Tried to work on seat heat but couldn't find access panel that goes under seat.
Started working on position of parking brake control lever. Didn't like unit I had previously acquired at ACS so called it a day and went and exchanged it for a different, smaller handle.
