Bonded in two layers of glass on right wingtip trailing edge. Will need to add one more layer and then start with the filler.
Final Torqued the four HS forward bolts.
Right tire took way too many weights to not completely balance, so today I took it apart. Rotated tire 180 degrees and reinstalled hub. Rebalanced with less than 1/3 the prior weight. Reinstalled tire on aircraft.
Went to final touchup primer on rudder bottom fairing, only to have wind blow it into the grass when I turned around.. Now I have to wait for it to dry, resand and reprime. UGH!
