Balanced nose tire and reinstalled on nose gear. Need to add additional washers to shock mount as reccommended is not sufficent. Getting new bolt as hole is drilled too close to the end of bolt.
Primed and riveted wingtip stiffener in place. Bonded in foam stiffener in preparation for reglassing tip trailing edge.
