Pulled both doors out and sanded with 220 grit on inside surfaces to prepare them for final interior top coat. Removed door handle hardware.
Sanded exterior of doors in preparation for final sanding surfacer coat.
Test fit the competed headliner insert and decided that the Lord Adhesive would show, so I masked off both rear windows and painted the visible adhesive strip a flat black that will blend in with the interior window trim.
