Flandy Rv-10
Date:  11-27-2013
Number of Hours:  3.00
Manual Reference:  37
Brief Description:  Fuel system #5
Continued adjusting system.
Will need to have right tank feed interior tunnel connection line shortened about 1/4".
Fabricated space to raise fuel pump mount up .125" to keep pump and red cube in allignment.
Installed fuel valve extension into lower u-joint. Trimmed extension and installed upper u-joint. Drilled hole and inserted expansion pin to lock u-joint in place.
