Brief Description: Door frames and Aft top skin install
Worked on sanding filler and trimming the four door post panels to fit. Need to add more filler in small sections and continue.
Dane came over and helped me work on aft top skin installation. Applied pro seal to cabin cover per plans and added a "liquid shim" to a small portion of the skin as the baggage bulkhead didn't quite reach the skin. This would have caused it to pucker in the respective corners when riveted. Riveted all but the double row of rivets at the cabin cover seam.
