Sanded left window edge with 220 grit sandpaper. Bonded left door window in place using Lord adhesive.
Worked on preppeing right door window for install. Right door was flexing too much during locking sequence. Removed door, fabricated and installed .032 shim under aft door hinge. Reinstalled door and rechecked. Still has a flex to it, but not as much. Removed plastic from inside of window and taped for install. Drilled holes for retaining clips. Finished trimming window size for best fit.
