After two weeks off due to vacation and work, it was time to get busy.
Pulled one brake cylinder because it was leaking out the top and set it back to Matco for inspection/repair.
I recieved my parts from TS Flightlines. Temp installed the forward lines from firewall to Red Cubes. Opened up the tunnel holes so fittings can pass through. Need fuel pump from Andair to finish rough in and ordering of remaining fuel lines.
Finished prepping hinges for priming.
Worked on blending GPS antenna mounts into to of the fuselage. Added more filler.
Drilled three in holes in upper forward fuselage above avionics. Fabricated doublers out of .063 sheet and drilled into fuselage. Deburred, dimpled, countersunk and ready to prime.
