Brief Description: Electrical planning and install
With fwd fuselage clecoed in place, I started working on roughing in the power distribution system.
Drilled and installed the Avionics relays on both the Main and Essential power distribution panels. With these in place, started working on fabricating wire connections between fuse blocks and relays. Working on routing main power cables from firewall pass-thru to fuse blocks.
