On instrument panel, marked and drilled two additional switch holes. Started opening for annunciator panel and cut opening to flush mount D10a. More to be done.
Dimpled fwd fuselage rib holes on firewall. Drilled/ deburred/ dimpled and installed nuplates for ground cable clamps and forward side panel attach points.
