Decided it was time to start fitting the forward interior panels from Aerosport Modeling. To do this right, I had to install some of the access panels and instrument panel to check for clearance. At this point I realized that the parts in image 2+3 should have been installed awhile ago. So, dig out the plans and figure out what fasteners to use and get them in- done. Also, my battery cable supports interferred with the panels fitting tightly to the sides, so out those came. Will need to fill rivet holes with 3-3 rivets.
