Flandy Rv-10
Date:  8-18-2012
Number of Hours:  6.00
Brief Description:  Aux Batt mount/ Doors/ Grd. Pwr plug + painting
Finsihed up final items on right aux battery mounts.
Sanded filler added for door lock mount on outside of doors.
For ground power plug, removed foure rivets from bottom of tailcone, match drilled into doubler.n Removed and finsihed drilling doubler rivet holes. Then match drilled from doubler into bottom skin. Dimpled skin and countersunk doubler fro dimples. Then cut, finled, and sanded plub opening into bottom skin. Ready to rivet.
Spent the rest of the time priming batt mounts and working with painter doing inside of cabin cover and other parts. Still some work to be done.
