Flandy Rv-10
Date:  6-15-2012
Number of Hours:  4.00
Manual Reference:  45,48
Brief Description:  GPU, GMU and more sanding
Continued working on ground power doubler.
Changed GMU44 location. Fabricated and drilled aluminum angle that will bolt onto rear seat shoulder harness mount middle bolt location. Drilled GMU hangar to angle for AN470-4 rivets. Ready for primer.
Finished sanding cabin cover. UV smooth prime requires 7 day cure then primer.
