Flandy Rv-10
Date:  5-9-2012
Number of Hours:  2.50
Manual Reference:  46
Brief Description:  Right Main/ Brakes/ Mid seat rails
Received replacement bearing seals while on a trip for work. Replaced damaged seals on right main tire and installed tire on spindle. Marked and removed axle nut. Removed tire and reinsatalled axle nut. Drilled 1/8" cotter pin holes. Removed nut and deburred. Reinstalled right main.
Installed correct An fitting in brake housings and installed both left and right brakes and brakes lines from fuselage to bakes. Need friction tape.
Finished torquing mid seat rail bolts.
