Installed fittings on parking brake valve. Fabricated left and right brake lines that run from parking brake to end of tunnel. Fabricated left and right brake lines from tunnel to gear mount fitting. Flaring and final install not complete.
Threaded rudder cables in place from back to front. Secured aft tubing with adel clamp per plans. Child labor required---small arms and hands-- thanks Eric.
Measured both control rods to plans specs. Installed safety wire on forward end of front rod. Bolted control rod idler arm in place.
