Flandy Rv-10
Date:  6-7-2011
Number of Hours:  3.00
Manual Reference:  38,39,42
Brief Description:  Controls/ Brakes/ Cabin Cover cont.
Fabricated F-1063C sapcer from .063 material per plans. Clecoed Idler arm together with spacer and bearing. Match drilled #30.
Separated rudder pedal sets. Clecoed rudder pedal, pedal doubler, and pedal side plate together. Match drilled each rudder pedal set.
Marked F-1039B bearing block for drilling. Clamped F-1039A bearing block and bearing block mount together. Match drilled #12 1/8 deep. Removed and final drilled block mount. Need longer #10 to complete this step.
Continued working cabin cover to finish fit to fuselage.
Fit almost right.
Fit almost right.
