Brief Description: Finished Sect 27 and More Fwd Fuselage
Completed riveting the bottom fuselage skins.
Fabricated two seat floor angles from stock. Marked centerline and drilled pilot hole. Final drilled seat floor cover #19. Cut apart seat floor and attach strip. Clecoed parts together and match drilled floor to strip and attach angle #40. Final drilled nutplates attach holes. Clecoed mid seat rail supports and match drilled #40,30.19, and 12 per plans. C-sunk all #40 holes in seat rail support and seat floor.
