Flandy Rv-10
Date:  8-25-2010
Number of Hours:  3.50
Manual Reference:  26-2,3,4
Brief Description:  Mid Fusealge Riveting
Dimpled holes on inboard seat assemblies for #8 screw. Riveted nutplates in place. Clecoed F-1016D seat belt attach bar and nutplate in place and riveted nutplate and opposite facing rivet. Clecoed remaining parts and riveted in place.
Dimpled holes on outbaord seat rib assemblies for #8 screw and buffed one per plans. Dimpled the F0115 spacer and intercostal for 3/32 rivets. Riveted the F-1016D trimmed seat belt attach bar and F-814HPP seat belt anchor to outbaord seat rib. Riveted the nutplates to F-1015B intercostals then riveted them to outboard seat rib.
Inserted Va-175 vent to inboard seat assemblies and then clecoed and riveted the Flap actuator bracket in place. Clecoed then bolted this assembly to the Aft center section bulkhead. Bolts torqued and sealed. Riveted the inboard seat rib assemblies to the aft center section. Clecoed and bolted the outboard seat rib assemblies to the aft center section. Bolts torqued and sealed.
Inboard seat ribs
Inboard seat ribs
Outboard seat ribs
Outboard seat ribs
