Brief Description: Installed AOA sensors and attached right LE
AFS- Verified locations and match drilled/dimpled holes for upper and lower air sensors in right wing.
Step 2+3 Deburred rib attachments. Clecoed right LE to wing. Riveted inobard and outboard ribs with An470 rivets and the rest with LP4-3 rivets. Riveted bottom leading edge to spar.
