Brief Description: Riveted ribs to spar and started aileron hinges
14-5 (Left wing)
Step 3 Riveted all ribs but farthest outboard to spar. Installed flush rivets on seven rib tabs between tank attach holes. Steve McDonald helped me rivet.
15-1
Step 1 Removed aileron stop tab from two hinge bracket spacers.
Step 2+3 Assembled inboard and outboard aileron hinge assemblies. Match drilled #30 holes common to all three pieces. C-sunk 5 holes in each per plans.
Step 4 Marked and disassembled parts for deburring and priming.
