Sanded right trailing edge and added more filler. Added filler around right aux tank fuel door.
Drilled right upper engine mount bolt. Installed upper two bolts. Checked lower four holes. Outer holes are ok, but inner two bolt connections need adjustment on the mount.
Sanded right elevator tip to HS spacing to create a more even opening referencing the left side.
Flap controller quit suddenly so I removed it and sent it back for repair.
