Drilled both hinges to wingtips. Adjusted openings to rought fit condition. Completed drilling opening stiffener to wingtips. Marked and drilled both supports for the Camloc nutplatel. Drilled both doors for Camlocs. Did some grinding on the inside of the wingtip to smooth out the excess epoxy buildup from all the different adjustments.
Took them to the hangar to test fit and check door clearances. Tips still need some modification to fit the wing easier.
