The aux fuel doors are not going to work the way I planned, so it is off to plan B. Will have to shift the hinge line from forward to inboard. Set door in place and bonded filler in place to close up opening.
Worked on body filler a little more. Found some small areas that needed filler. Will try to finish up this stage of work this weekend.
