Left wing-- Match drilled inboard tank support flanges #30 and final drilled #12. Installed tank and adjusted outboard end to appropriate final location. Traced outline and removed tank. Using supplied .040 stock and 3/4" aluminum angle, fabricated forward mount stiffener. Match drilled to rib flange and rib web.
