Riveted rod end sub-assemblies together. Riveted the left and right hinge pair rib sub-assemblies together, then installed the bolt and double-flush riveted the joggle. Riveted the center hinge sub-assembly together. Rivets called for in plans were a little short, so I cut some longer rivets to the correct length.
