Step 3 Removed HS and deburred shims and aft deck holes that were drilled. Waiting to prime before continuing.
11-8
Step 1+2 Fabricate trim bellcrank bracket and cable anchor bracket
Step 3 Deburred and fit F-1095F trim servo spacer to underside of F-1095A trim mount bracket.
Step 4 Clecoed F-1095F to F-1095A via four edge holes. Clecoed F-1095C trim bellcrank brackets and F-1095G trim cable anchor bracket to F-1095A trim mount bracket. Match drilled holes #30.
