Brief Description: Finished Tip ribs and bent Elev skin tabs
Finished tip rib straigthening and flange 90 degree setting.
Deburring all elevator skins.
Step 1 thru 3
Marked bend line according to plans. Clamped skins betweeen bench and wood block. Initially used wood block to start bend of tab. Finished with flush rivet set on very low pressure. Worked great.
