Cut rudder stiffenfers to appropriate length and deburred. Clecoed R1004a+b together and final drilled #30. Deburred Rudder horn R1005 and CSK four marked locations. Clecoed R1005 and R1004 and match drilled. Deburred R1002 Spar and clecoed to bottom rib. Match and final drilled as required. CSK striker plates. Assembled stiffeners and shear clips and match drilled. Assembled all to R1002 spar along with reinforcement plates. Final drilled #30 all common holes.
