Brief Description: Cowling Day #3 and Baffles day #22
Upper cowl modification--cut and drilled reference holes in spinner template. Cut and attached postioning angles to aft template. Marked cowl for cutting and determined best way forward.
Completed cabin heat exchanger ducting.
Started working on completing baffle installation. - deburred and adjusted #3 cylinder lower baffle. - deburred and trimmed #3 cylinder outside baffle -deburred and trimmed #4 cylinder outside baffle -Attached, deburred and trimmed #4 cylinder lower baffle -Adjusted and trimmed left rear baffle. Almost ready to drill upper to lower attach points.
