Located and drilled FW for prop cable. Final drill of throttle/prop/alt air cable pass thru will have to wait for engine removal as there is no room to reach.
Routed cable and tested clamps along the way.
Deteremined that I would have to special order the cables with bulkhead fittings to connect to the DJM quadrant. Ordered prop cable and will use it to determine throttle cable length.
