Brief Description: Oil cooler and fuel lines day #2
Ordered new oil cooler after determining correct sizing for location.
Completed fuel return to fuel cooler hose fabrication with fire sleeve.
Decided to reuse previously made fuel line hose for connection from pressure block to engine inlet. Will need to change on fitting and add fire sleeve.
Worked on routing CHT/EGT wiring and started working on Prop Accum location and Cabin heat oil cooler.
