Using 3" valve as a template, fabricated a 2.5" version. Had tube stretched at Meineke and then cut to proper length. Drilled pivot holes and deburred. Cut butterfly valve and trimmed to correct size. Then assembled unit.
Ran Music #2 input from tunnel thru right battery area and down right sidewall. Currently terminated in rear seat cross bar.
