Awol power supply finally arrived. Finished calibrating throttle POTs connection. Now matches engine ECU mapping. One final adjustment and back to DJM for labeling.
Replaced several fittings in engine sensor block to allow additional oil pressure sensor. Sensor on order.
Fuel cooler arrived. After reviewing potential locations, I ordered the Van's oil cooler mount as that makes the most sense.
Will add switch to allow selecting IN and OUT fuel temps.
