Recieved fuel sensor mount. Using an unsed nutplate for one hole, drilled two other holes and deburred. Installed ( temporarily?) mount and fabricated fuel line from bulkhead fitting to sensor block. Intsalled both sensors and reconnected output to return line. Tested for leaks.
Need to firesleeve and test senors with temp connetions.
