Flandy Rv-10
RV-10
14-3,4,5 and 15-2
Flap Hinge and Aileron Bracket Riveted
(Right wing)
14-3 step 5-8 Riveted flap hinge assembly to ribs. Riveted torque tube assembly together and attached to inboard rib.
14-4 step 2 Drilled wire run penetration to 5/8' with step drill.
14-5 step 2 Clecoed ribs to right wing spar.
15-2 steps 5-7 Pressed bearing into W-1013a hinge spacer. Riveted aileron brackets together.
RV-10 Home
3570
330
284
918
1411
579
