Flandy Rv-10
RV-10
14-2 and 14-3
Torgue Tube and Flap Hinge Assemblies
Step 4 Cut W-1029E spacer
Step 5 Match drilled 1029D+E to W-1029A-L torque tube bracket
Step 6 Clecoed VA146 to W-1029A+B and clecoed to W-1010 wing rib. Clamped -1029C to
assembly.
Step 7 Match drilled 1029C to wing rib.
Step 8 Match drilled 1029C to torque tube bracket. Match drilled remaining holes #30.
Step 9 Clecoed Flap hinge rib and flap hinge bracket to inboard wing rib, Final drilled #30 common holes.
Step 10 Clecoed Flap hinge ribe and flap hinge bracket to W-1011-L. Match drilled #30 common holes. Two assemblies completed.
14-3
Step 1 Removed flange per plans from single W-1011L. (image 3)
Step 2 Removed aft flange but not radius from single W-1012R
RV-10 Home
3570
330
284
918
1411
579
