Flandy Rv-10
RV-10
11-4 to 11-5
HS to tail cone attachment
11-4
Step 1 Final drilled VS-1016 VS attach hole to 1/4" and match drilled to HS #12.
Step 2 Fabricated F-1098shims per plans.
Step 3 Attached shims to VS
Step 4 Installed HS on tailcone and matched drilled VS aft spar to F-1011C attachment bars #12.
Installed hardware per plans.
11-5
Step 1 Cut wood block to fit between fron attach points and clamped in place.
RV-10 Home
3570
330
284
918
1411
579
