Flandy Rv-10
Date:  8-31-2016
Brief Description:  Cowling Day #60
Short day due to work.
Primed upper cowl pin retainer clip parts
Added more layers to align right lower inlet with baffling. Started sanding back side for baffle gap seal.
Sanded oil reservoir inside of the cowling. Added one layer of glass and left to cure. It was test fit on aircraft and provides adequate space for engine movement.
Looked at air cleaner placement when cowling was installed.
